crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Move the battery lock switch to the right to unlock. The battery release button will unlock the battery from the computer.
The battery release button is located above the the battery.
The battery will unlock from the computer.
Remove the unlocked battery from the computer.
Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
Remove the HP protect smart ventilation case.
Remove seven 6.5 mm screws using a Phillips #0 screwdriver.
Remove four 3.0 mm screws located in the charger port using a Phillips #0 screwdriver.
Pull and remove the disk drive.
Remove two 3.00 mm screws on the inside of the disk drive using a Phillips screwdriver.
Apply firm pressure inside the release port using a narrow tool such as a screw driver or tweezers.
Flip device over so that the cover is facing towards you
Open device. The keyboard should be separate from the inside panel.
Detach the keyboard's cable connector from the motherboard.
Remove three 6.5 mm Phillips screws located underneath the keyboard using a Phillips #0 screwdriver.
Place wedge tool in-between the front panel and the cover underneath the keyboard
Use wedge tool to pop the two covers apart.
Remove the motherboard using your hands
