HP Pavilion 15-eg0025nr Screen Replacement
  1. HP Pavilion 15-eg0025nr Screen Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug and turn off the laptop before removing the back panel
    • Flip over the computer so that the back panel is facing upwards.
    • Remove the two silver screws on the bottom of the laptop using a Phillips #00 screwdriver.
  2. HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel up each end of the two gray rubber stoppers using your fingers or an opening pick.
    • This may be difficult if it is your first time removing them.
    • Remove the two black screws underneath the rubber stoppers with the Phillips #00 screwdriver
  3. HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick around the edges of the laptop where the chassis has a seam.
    • You will hear a clicking noise as you undo the clips of the chassis.
    • It may be easier to start with the four corners of the laptop, and then follow through with the sides.
  4. HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back panel completely.
    • With the back panel removed, you can now access parts of the laptop such as the fan or the battery.
  5. HP Pavilion 15-eg0025nr Screen Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five screws from the battery using a Phillips #00 screwdriver.
  6. HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from the laptop.
  7. HP Pavilion 15-eg0025nr Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-eg0025nr Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-eg0025nr Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not attempt to remove the screen without first removing the back panel and battery. Ensure that the laptop is powered off before removing the screen
    • Find the hinge bezel where the display bezel meets the back panel.
    • Using an opening pick, unclip the hinge bezel by sliding the pick along the hinge.
  8. HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an opening pick, pry open the top, sides, and bottom of the display bezel.
    • Remove the display bezel and set aside.
  9. HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six golden screws with a Phillips #00 screwdriver and set aside.
    • There are three screws on each side.
  10. HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two silver screws at the top of the display panel with a Phillips #00 screwdriver.
  11. HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-eg0025nr Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an opening pick, carefully pry the screen from top, sides, and bottom of the display panel.
    • Be cautious to not bend or snap the screen as you pry it out.
    • Remove the screen and set aside.
Elaina Bonner
crwdns2935283:009/06/22crwdne2935283:0
337 crwdns2915208:0crwdne2915208:0
University of Colorado Denver, Team 1-1, Campeau Fall 2022 crwdns2935289:0University of Colorado Denver, Team 1-1, Campeau Fall 2022crwdne2935289:0
UCDENVER-CAMPEAU-F22S1G1
crwdns2942667:0crwdne2942667:0 1,470
