HP Pavilion 15-cd040wm Back Cover Disassembly
  1. HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Back Cover Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-cd040wm Back Cover Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Back Cover Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-cd040wm Back Cover Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-cd040wm Back Cover Disassembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
Joe Krawczyk
crwdns2935283:011/01/19crwdne2935283:0
397 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 crwdns2935289:0UMass Dartmouth, Team S1-G1, Botvin Fall 2019crwdne2935289:0
UMASSD-BOTVIN-F19S1G1
It's not listed in here, but to remove the cd tray, just pull it straight out. The whole drive has a connector at the back.
Gage Cook - crwdns2934203:0crwdne2934203:0
I’m trying to remove my backing and it seems to have a lip that goes over the edge, so I’m having a hard time getting it apart. Any suggestions?
Laura Green - crwdns2934203:0crwdne2934203:0
Is this the same process for the HP Pavilion 15-cc055od? Do I pull out the disk drive as well? How would I remove the hard drive?
Baconface Smith - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 125
crwdns2942667:0crwdne2942667:0 10,336
