HP Pavilion 15-cc561st RAM Replacement
    1. HP Pavilion 15-cc561st RAM Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-cc561st RAM Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-cc561st RAM Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      Magnetic Project Mat
      $19.95
      • Before you begin to remove the bottom cover, shut down the computer. Disconnect all external devices and unplug the AC adapter. Flip the laptop upside down.
      • Use a Phillips #0 screwdriver to remove five screws from the bottom cover:
      • Two 5.6 mm screws
      • Each of these screws are beneath the two rubber feet on the rear side of the laptop (near the display hinges). You do not have to completely remove the rubber feet to remove the screws; simply peel the top of the feet to reveal the screws.
      • Three 5.8 mm screws
      • Throughout this repair, keep track of each screw size and location to avoid damaging your device.
    2. HP Pavilion 15-cc561st RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-cc561st RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert an opening tool into the space between the display hinges and the bottom cover.
      • Firmly push the opening tool upwards to separate the bottom cover from these areas.
    3. HP Pavilion 15-cc561st RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-cc561st RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-cc561st RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert your opening tool and firmly push the tool upwards along the rear edge.
    4. HP Pavilion 15-cc561st RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-cc561st RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-cc561st RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the opening tool again on the left and right sides.
      • Start prying at the areas closer to the rear of the laptop (near the display hinges) before moving towards areas that are closer to the front of the laptop (away from the display hinges).
      • Pry a little bit on the left side, then pry a little bit on the right side before prying more on the left side again. Working on both sides in this incremental fashion is easier than completely prying one side before starting the other side.
    5. HP Pavilion 15-cc561st RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the bottom cover upwards to remove it.
    1. HP Pavilion 15-cc561st RAM Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #0 screwdriver to remove the five 5.7 mm screws that secure the battery.
    2. HP Pavilion 15-cc561st RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-cc561st RAM Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-cc561st RAM Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the battery towards the front edge of the laptop to disconnect it from the 8-pin battery connector.
      • Lift the disconnected battery upwards to remove it.
      • Calibrate a newly-installed battery to help your laptop get an accurate battery percentage reading.
    1. HP Pavilion 15-cc561st RAM Replacement, RAM: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-cc561st RAM Replacement, RAM: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-cc561st RAM Replacement, RAM: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Simultaneously spread the retaining tabs on each side of the memory module slot.
      • Releasing the tabs will cause the memory module to "pop" up (the edge of the module opposite the slot rises up).
      • Pull the memory module away from the slot at the angle it rises from.
      • Line up the notch on a new memory module with the slot. This notch is designed to prevent incorrect insertion.
      • If only one memory module is installed, it must be installed in the socket that is closer to the center of the computer.
Nathan Luu
crwdns2935283:009/26/22crwdne2935283:0
569 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 6-4, Adachi Fall 2022 crwdns2935289:0CSU Los Angeles, Team 6-4, Adachi Fall 2022crwdne2935289:0
CSULA-ADACHI-F22S6G4
crwdns2935297:084crwdne2935297:0
crwdns2942667:0crwdne2942667:0 662
