Use this guide to replace the heat sink in a HP Pavilion 15-cc561st (product number 1KU29UA).
The heat sink is an important component that keeps the processor cool. It transfers heat from the processor through heat pipes to a fin-stack which transfers heat to the ambient air. Thermal paste helps maximize heat transfer between the processor and heat sink, so it is important to reapply thermal paste before reinstalling the heat sink.
Shut down the laptop, disconnect all external devices, and unplug the AC adapter before beginning. Take the appropriate precautions if your battery is swollen.
You will need replacement thermal paste in order to complete this repair.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a Phillips #0 screwdriver to remove five screws from the bottom cover:
Two 5.6 mm screws
Three 5.8 mm screws
Insert an opening tool into the space between the display hinges and the bottom cover.
Firmly push the opening tool upwards to separate the bottom cover from these areas.
Insert your opening tool and firmly push the tool upwards along the rear edge.
Use the opening tool again on the left and right sides.
Start prying at the areas closer to the rear of the laptop (near the display hinges) before moving towards areas that are closer to the front of the laptop (away from the display hinges).
Lift the bottom cover upwards to remove it.
Use a Phillips #0 screwdriver to remove the five 5.7 mm screws that secure the battery.
Pull the battery towards the front edge of the laptop to disconnect it from the 8-pin battery connector.
Lift the disconnected battery upwards to remove it.
Disconnect the fan cable from the motherboard.
Use a Phillips #0 screwdriver to remove the three 5.8 mm screws that secure the fan.
Use a Phillips #0 screwdriver to remove the four 3.0 mm screws that secure the heat sink.
Lift the heat sink upwards to remove it.
