HP Pavilion 15-ca2073cl Display-Pad Replacement
  1. HP Pavilion 15-ca2073cl Display-Pad Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl Display-Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-ca2073cl Display-Pad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl Display-Pad Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-ca2073cl Display-Pad Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
  4. HP Pavilion 15-ca2073cl Display-Pad Replacement, Display-Pad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the laptop like you normally would if you were about to use it and use a plastic spudger to separate the top cover from the bottom.
    • While lifting the top cover, undo the clip holding the keyboard cable in place and pull the cable out.
  5. HP Pavilion 15-ca2073cl Display-Pad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-ca2073cl Display-Pad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws from the display to the frame of the laptop.
    • Remove the cables that connect to the motherboard.
  6. HP Pavilion 15-ca2073cl Display-Pad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the display from the rest of the laptop.
  7. HP Pavilion 15-ca2073cl Display-Pad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, remove the cover from the display pad.
  8. HP Pavilion 15-ca2073cl Display-Pad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-ca2073cl Display-Pad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws surrounding the display.
    • Using the spudger, pry the display from the display pad.
Montray Robinson
crwdns2935283:002/20/20crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S2-G10, Eggleston Spring 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S2-G10, Eggleston Spring 2020crwdne2935289:0
CMCSC-EGGLESTON-S20S2G10
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 47
