This guide will assist you in replacing the keyboard cover on your HP Pavilion 15-bk020wm device. Your device might need this replacement due to rough handling. This is also a prerequisite guide for further device dismantling.
Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
Remove the two screw cover strips.
Remove the two screw cover plugs.
Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
Turn the computer over to the front.
Open the laptop.
Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
Tilt the keyboard cover up slightly.
I don’t have the 2 orange screws under my laptop, but when I unscrew the other 10, and try to lift the keyboard, I can’t lift it fully because it’s being held down by something.
The ribbon cables for the keyboard and trackpad are held in place by some clips. Unlatching those clips allow you to carefully remove the ribbon cables and place the keyboard assembly aside. This gives more room for removing the hard drive.
two questions
Where can i get these tools?
Will these instructions work for HP Notebook - 15-db0019au ?
