HP Pavilion 15-b109wm Hard Drive Replacement
  1. HP Pavilion 15-b109wm Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm Hard Drive Replacement, Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement, Keyboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Heavy-Duty Spudger
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
  11. HP Pavilion 15-b109wm Hard Drive Replacement, Fan: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement, Fan: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement, Fan: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a JIS #1 screwdriver, remove the five 5mm screws.
    • Detach the power button cable.
    • Detach the touch pad cable.
  12. HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, pry open the top cover.
    • Unscrew the two 5 mm screws using a JIS #1 screwdriver.
    • Gently, pull to detach the fan cable.
    • Be careful so you do not damage the motherboard.
  13. HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the fan from its slot.
  14. HP Pavilion 15-b109wm Hard Drive Replacement, Hard Drive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement, Hard Drive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement, Hard Drive: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the cables to the motherboard.
  15. HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-b109wm Hard Drive Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hard drive.
To reassemble your device, follow the instructions in reverse order.
Enrico Miozzo
crwdns2935283:011/07/19crwdne2935283:0
244 crwdns2915208:0crwdne2915208:0
IUPUI, Team S2-G4, Harley Fall 2019 crwdns2935289:0IUPUI, Team S2-G4, Harley Fall 2019crwdne2935289:0
IUPUI-HARLEY-F19S2G4
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 902
