HP Pavilion 15-au123cl RAM Replacement
  1. HP Pavilion 15-au123cl RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-au123cl RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-au123cl RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-au123cl RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-au123cl RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-au123cl RAM Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl RAM Replacement, RAM: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-au123cl RAM Replacement, RAM: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The RAM is located at the lower middle region of the motherboard.
    • Push down on the clips on both sides of the RAM stick evenly.
    • The RAM will become loose and move upward when the clips are pushed.
  7. HP Pavilion 15-au123cl RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the RAM stick out of the motherboard.
    • The same steps work on both sticks of RAM.
Mohammad Gardezi
crwdns2935283:010/17/17crwdne2935283:0
1 420 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S13-G3, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S13-G3, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S13G3
Thanks mate….your steps are helpful <3
Can you please guide on how to buy the RAM for this laptop…my current RAM is 4GB
Im planning to upgrade to 8GB
thanks
Gokul Prasad Rao - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,416
