HP Pavilion 15-ab243cl Hard Drive Replacement
  1. HP Pavilion 15-ab243cl Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery lock tab toward the center of the battery to the unlock position.
  2. HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the battery release switch to the right until the battery pops out.
  3. HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot.
  4. HP Pavilion 15-ab243cl Hard Drive Replacement, Laptop Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement, Laptop Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement, Laptop Case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
  5. HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all 16 of the 3.5 mm screws with a PH1 screwdriver and pry/slide the CD drive out of laptop.
  6. HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the CD drive removed, unscrew the two 2mm silver screws with a PH00.
    • These can strip easily, so take your time removing.
  7. HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, begin to pry edge of case away from the laptop. Work around the edges until all sides, except back, are open.
  8. HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the back side of the laptop, where the battery is, there are 12 black plastic clips. Use a plastic opening tool and pry all of these clips, unlatching them from the case.
    • Once clips are free, open the laptop. Rotating the case off, around the hinges, works best to remove the case.
  9. HP Pavilion 15-ab243cl Hard Drive Replacement, Hard Drive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement, Hard Drive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement, Hard Drive: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the hard drive and lift up to give better access to the connector.
  10. HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool or spudger, pry open the white tab to release connector.
  11. HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15-ab243cl Hard Drive Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hard drive is good to go and can now be removed.
Alexander Bicigo
crwdns2935283:002/14/18crwdne2935283:0
942 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S6-G3, Eyestone Spring 2018 crwdns2935289:0USF Tampa, Team S6-G3, Eyestone Spring 2018crwdne2935289:0
USFT-EYESTONE-S18S6G3
crwdns2942667:0crwdne2942667:0 1,801
