HP Pavilion 15 P Series Motherboard Replacement
  1. HP Pavilion 15 P Series Motherboard Replacement, Shutdown Laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before working on the laptop, make sure it is shut down.
  2. HP Pavilion 15 P Series Motherboard Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15 P Series Motherboard Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15 P Series Motherboard Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the locking tab to the right showing a unlocked symbol.
    • Then pull the release tab to the left, releasing the battery.
    • Lift the battery out of its connection.
  3. HP Pavilion 15 P Series Motherboard Replacement, Remove Optical Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15 P Series Motherboard Replacement, Remove Optical Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the single Phillips #0 screw that holds the optical drive in place.
    • Using a spudger push the optical drive out.
    • Pull the optical drive completely out and set it to the side.
  4. HP Pavilion 15 P Series Motherboard Replacement, Remove the Hinge Caps: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15 P Series Motherboard Replacement, Remove the Hinge Caps: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15 P Series Motherboard Replacement, Remove the Hinge Caps: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, pry up the rubber cap.
    • Remove the single screw underneath the cap.
    • Slightly lift up on the marked section of the hinge cap. Pull away from the computer to release the cap.
    • Remove the hinge screw.
    • Repeat all steps on the other side.
  5. HP Pavilion 15 P Series Motherboard Replacement, Remove Bottom Screws.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove each of the highlighted screws.
    • Note, this screw is sometimes covered by a cap.
    • Remove the silver pan head crew in the optical drive bay.
  6. HP Pavilion 15 P Series Motherboard Replacement, Remove the Top Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15 P Series Motherboard Replacement, Remove the Top Case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15 P Series Motherboard Replacement, Remove the Top Case: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip your computer back over and open the display. Using a sputter, opening tool, guitar pick, or card pry up on the top case between the frame and itself.
    • Follow all the way around the top case gently, until the keyboard is able to be lifted freely.
    • NOTE* Do not lift the keyboard off until the next step in which we pull the ribbon cable connections.
    • Using your spudger, or prying tool lift the releases for each ribbon cable. *Be cautious when removing and handling ribbon cables as they are very fragile.
    • Lastly, remove the last two ribbon cables located at the top of the keyboard.
  7. HP Pavilion 15 P Series Motherboard Replacement, Removing the Mother Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 15 P Series Motherboard Replacement, Removing the Mother Board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 15 P Series Motherboard Replacement, Removing the Mother Board: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove each cable and connection to the logic board.
    • Next, remove the screws holding the motherboard to the bottom case.
    • There may be a screw in this area, there was not in the computer I worked on.
    • Remove the screw holding the wifi card in place. Pull the wifi card out.
  8. HP Pavilion 15 P Series Motherboard Replacement, Finish Removing the Mother Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The hardest connection to remove, this is the cable to the AC/DC power port. Remove it by pulling the outside edges of the connector and wiggling gently.
  9. HP Pavilion 15 P Series Motherboard Replacement, Transfer the Fan to the New Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 15 P Series Motherboard Replacement, Transfer the Fan to the New Motherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fan by disconnecting the white pin connector and then removing the only Phillips crew holding the fan in place.
    • Now you're ready to put the new logic board in!
crwdns2935229:011crwdne2935229:0
help
crwdns2935283:007/24/14crwdne2935283:0
494 crwdns2915208:0crwdne2915208:0
Out of a Jam Solutions crwdns2935289:0Out of a Jam Solutionscrwdne2935289:0
Business
Thanks for this guide. Apparently the RAM is on the underside of the logic board?
I have a HP 15-P189NA which could do with a RAM upgrade.
Douglas Bateman - crwdns2934203:0crwdne2934203:0
Das Modell 15-P151NG ist etwas anders, hilft trotzdem die Anleitung.
Alex Barblexi - crwdns2934203:0crwdne2934203:0
Ich wäre an dem defekten Mainboard interessiert.
Bernd Dreyer - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 153
crwdns2942667:0crwdne2942667:0 17,158
