HP Pavilion 14-v062us Keyboard Replacement
    1. HP Pavilion 14-v062us Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-v062us Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Power laptop off and make sure it is not plugged into charger
      • Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
    2. HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the battery upwards and out from the laptop
    1. HP Pavilion 14-v062us Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove rectangular rubber tops with a spudger
      • Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
      • Remove plastic edge covering with the blue plastic opening tool.
      • Remove two 4.63 mm PH#1 screws located under plastic edge covering.
    2. HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use Phillips screwdriver #1
      • Remove all nine 7.09 mm PH#1 screw black screws including small rectangular cover.
      • Remove the three 7.14 mm PH#1 screws.
      • Remove the one 7.09 mm PH#1 screw that will be underneath the small rectangular cover
    3. HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove disc tray
      • Locate screw within computer that is inside of where the disc tray was
      • Using a Phillips #1 screwdriver, unscrew the screw
      • Set laptop down and open laptop so the keyboard is facing you
    4. HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a spudger or plastic opening tool, pry along siding of keyboard, where it connects to the rest of the laptop
      • Pry until you are able to lift entire face and keyboard
      • Only cables should be connecting it underneath
    5. HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect/ unplug cables using plastic opening tool.
      • Separate the keyboard panel from the laptop with your hands.
      • Turn around the laptop and lay it flat.
    6. HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to pry around the first layer of the silver panel until you are able to remove it
      • Only use a metal spudger as a last resort
    7. HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Keyboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a spudger tool, start prying around the second layer of the silver panel until you are able to remove it
Flora Peterson
crwdns2935283:009/21/17crwdne2935283:0
233 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G4, Carnegie Fall 2017 crwdns2935289:0Eastern Washington University, Team S1-G4, Carnegie Fall 2017crwdne2935289:0
EWU-CARNEGIE-F17S1G4
crwdns2935297:048crwdne2935297:0
Thank you so much, this guide is very helpful.
Rodolfo Trujillo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you for the guide. It was very helpful!
dmitryp80 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 2,497
