HP Pavilion 14-v062us Fan Replacement
  1. HP Pavilion 14-v062us Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power laptop off and make sure it is not plugged into charger
    • Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
  2. HP Pavilion 14-v062us Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery upwards and out from the laptop
  3. HP Pavilion 14-v062us Fan Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement, Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement, Keyboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove rectangular rubber tops with a spudger
    • Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
    • Remove plastic edge covering with the blue plastic opening tool.
    • Remove two 4.63 mm PH#1 screws located under plastic edge covering.
  4. HP Pavilion 14-v062us Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use Phillips screwdriver #1
    • Remove all nine 7.09 mm PH#1 screw black screws including small rectangular cover.
    • Remove the three 7.14 mm PH#1 screws.
    • Remove the one 7.09 mm PH#1 screw that will be underneath the small rectangular cover
  5. HP Pavilion 14-v062us Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove disc tray
    • Locate screw within computer that is inside of where the disc tray was
    • Using a Phillips #1 screwdriver, unscrew the screw
    • Set laptop down and open laptop so the keyboard is facing you
  6. HP Pavilion 14-v062us Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger or plastic opening tool, pry along siding of keyboard, where it connects to the rest of the laptop
    • Pry until you are able to lift entire face and keyboard
    • Only cables should be connecting it underneath
  7. HP Pavilion 14-v062us Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect/ unplug cables using plastic opening tool.
    • Separate the keyboard panel from the laptop with your hands.
    • Turn around the laptop and lay it flat.
  8. HP Pavilion 14-v062us Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry around the first layer of the silver panel until you are able to remove it
    • Only use a metal spudger as a last resort
  9. HP Pavilion 14-v062us Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger tool, start prying around the second layer of the silver panel until you are able to remove it
  10. HP Pavilion 14-v062us Fan Replacement, Fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement, Fan: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement, Fan: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all 6 screws (5.65 mm) from the motherboard, using Phillips screwdriver J0
    • There will be a silver covering (in a z shape) that needs to be removed using black tweezers or a plastic opening tool
  11. HP Pavilion 14-v062us Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5.66mm screws from the motherboard using Phillips head screwdriver J0
  12. HP Pavilion 14-v062us Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove entire motherboard from the laptop
    • Turn over and remove the single 5.63mm screw using a Phillips head screwdriver J0.
  13. HP Pavilion 14-v062us Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 14-v062us Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove wiring with plastic opening tool
    • Remove fan
Lorena Esquivel
crwdns2935283:009/27/17crwdne2935283:0
247 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G4, Carnegie Fall 2017 crwdns2935289:0Eastern Washington University, Team S1-G4, Carnegie Fall 2017crwdne2935289:0
EWU-CARNEGIE-F17S1G4
crwdns2942667:0crwdne2942667:0 1,698
