If your HP Pavilion 14-b015dx is not holding its charge, it probably needs a battery replacement. These instructions will help you to quickly remove the battery with minimal skill or effort.
When a battery is working correctly it should provide the laptop with power for several hours without being plugged into a power source. After several cycles of being charged, the battery will begin to lose ability to hold a charge. You can check the charging capacity by calibrating your battery. If there is a drop in the battery percentage, you should consider replacing the battery.
Be sure the laptop is powered off before replacing its battery.
Take appropriate precautions if the battery is swollen. Beware of punctured batteries as they can cause fires.
Place the device on your work surface with bottom facing up and the battery located at the top.
Slide the left release tab toward the center of the computer to the unlock position. Next slid the right tab toward the center of the computer and hold it there while completing step 4.
Remove the battery by sliding it upwards and away from the computer.
