HP Pavilion 13-P110NR Screen Replacement
  1. HP Pavilion 13-P110NR Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back of the laptop screen using a black nylon spudger.
  2. HP Pavilion 13-P110NR Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the wires from the green circuit boards located at the bottom.
    • Remove three 3.0 mm #00 Philips screws from the circuit board on the left.
    • Remove two 4.0 mm #00 Philips screws from the small circuit board on the right.
  3. HP Pavilion 13-P110NR Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the wires located just above the bigger green circuit board.
  4. HP Pavilion 13-P110NR Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 13-P110NR Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove six 4.0 mm Philips #00 screws from the outside of the frame.
    • Remove five 3.0 mm Philips #00 screws from the outside of the frame.
    • Remove the one 3.0 mm Philips #00 screw hidden under the circuit board.
  5. HP Pavilion 13-P110NR Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the band that is attached to the circuit board, located on the right side.
  6. HP Pavilion 13-P110NR Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the frame and attached hardware from two corners of the frame.
    • Remove the frame from the device.
  7. HP Pavilion 13-P110NR Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 13-P110NR Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape located at the top of the frame.
    • Remove the bands from underneath the tape.
  8. HP Pavilion 13-P110NR Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 13-P110NR Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to lift the case, which is attached at four spots by pegs.
    • Remove the metal cover and layers of film.
  9. HP Pavilion 13-P110NR Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to gently lift up the screen.
    • There are two layers, go under the bottom layer.
  10. HP Pavilion 13-P110NR Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After you get some space at the top of the screen, proceed by using a thin board to gently remove the screen from the frame.
Matthew "Cole" Corson
crwdns2935283:001/18/18crwdne2935283:0
742 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S2-G5, Munoz Winter 2018 crwdns2935289:0Eastern Washington University, Team S2-G5, Munoz Winter 2018crwdne2935289:0
EWU-MUNOZ-W18S2G5
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 497
