HP Pavilion 11 x360 Fan Replacement
  1. HP Pavilion 11 x360 Fan Replacement, Remove Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 11 x360 Fan Replacement, Remove Screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Fan Replacement, Remove Backing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 11 x360 Fan Replacement, Remove Backing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 11 x360 Fan Replacement, Remove Backing: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Fan Replacement, Detach Cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 11 x360 Fan Replacement, Detach Cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Fan Replacement, Remove Screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm screws with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
Natalie
crwdns2935283:001/22/15crwdne2935283:0
940 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-9, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 19-9, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S19G9
crwdns2942667:0crwdne2942667:0 3,115
