This should apply to many similar HP Pavilion laptops of similar age.
There are a few little tricks to opening this to access the RAM slots hard drive.
Start by disconnecting the power cord, then turn over and remove the battery
There are a large number of screws visible on the bottom, they are all the same size and length, remove them all.
There are two screws hidden under silver stickers, indicated by the orange circles, remove the stickers and the screws underneath.
Remove the optical drive, if all the screws have been removed is should slide out easily.
Use a guitar pick to release the plastic clips at the points shown on the black covers near the hinges.
If you just pry the black covers off a small clip will break but the clips are not important.
Once the covers are off, remove two more screws from underneath the covers.
All of the screws are the same as the ones already removed.
the model I had had screws underneath the rubber feet on those two black pieces. I had to pry off the rubber feet and remove the screws underneath so that I could pry up these two black corner pieces.
Turn the laptop back upright and open the lid
Using a guitar pick, release the plastic retaining clips that hold the bottom of the case on.
Release the areas marked with green first, then the yellow and last the orange.
Close the lid and turn the unit upside down again.
The bottom cover should now be free, lift the front part first and push the cover toward the hinges.
If the cover resists make sure you have removed all the bottom screws including the two hidden under stickers.
my model had two screws that became visible after removing the CD drive - they were silver and had a much larger head than the other screws. I had to remove those to be able to lift the keyboard up.
klasse, vielen dank!
nachdem ich mich mit einem video mehrere stunden beschäftigt habe, ohne erfolg, habe ich durch zufall diese beschreibung gefunden.einfach, klar und funktionell!!! hat auf anhieb geklappt und ich habe eine ssd eingebaut und die bios batterie getauscht. bei dieser gelegenheit auch gleich den lüfter komplett gesäubert.
vielen dank für die klasse beschreibung! -
With the bottom cover removed the hard drive and RAM are easily accessible.
The hard drive is held in only by friction,
To remove the hard drive from its mount lift the drive a bit from the end near the data and power cables
Disconnect the power and data cables, the cable is a delicate ribbon cable so be gentle, don't pull it out or the way too far.
Lift the cable end a bit more and slide the drive towards the ram a bit to release the clips holding down the other end.
the mounting frame can just be pulled free from the drive, it is also only attached by friction.
my model had a ribbon cable that went across the length of the Harddrive requiring its removal to access the harddrive. Removing the cable from the motherboard was a problem - I was unable to successfully unplug it. The cable attached to a small circuit board containing a usb port and microphone connection - I was able to remove two screws holding down that circuit board and then lift it out of the way, enabling me to remove the HDD
When reassembling, keep the unit upside down and slide the bottom cover back into place hinges first.
It is a little fiddly getting the clips near the hinges and battery compartment seated.
Once the hinge area is close to being tight enough to push the clips back together, run your fingers down the sides by the keyboard to clip the sides and front.
Turn the unit upright open the lid and slide your fingers along the edge under the display and all the way around the edge to be sure all of the clips are back in place.
Reinstall the optical drive.
Turn the unit upside down again.
Replace the screws that will be hidden under the black covers by the hinges.
Replace the black covers by the hinges and then all of the rest of the screws. Don't forget the cover stickers for the two hidden screws.
Getting the hinges to line up and snap back into place was a BEAR! I finally had to slightly pry up on the plastic above the hinge to get the cover to snap into place. After that everything lined up easily. Hopefully that hint helps some other poor soul! :)
crwdns2935229:032crwdne2935229:0
crwdns2944067:022crwdne2944067:0
Very good tutorial. The cover is a pain to open but with your input, it worked great.. thanks!
Now, I must ask, how do I replace the keyboard??? Can it be done?
I don't have access to one of these right now, the one used for the guide was in for an upgrade, but looking at my photos it looks like there is a metal plate under the mainboard that holds the keyboard in place and it looks like it is held in place by melted plastic.
It that is the case, the official method would be a replacement assembly that includes the keyboard the retaining plate and the cover plate that the keyboard mounts through, moving all the electronic bits over.
The MacGyver method, (if you can get a replacement keyboard alone) would be to remove all the parts that block the keyboard retaining plate, break it loose to remove the dead keyboard and use glue to reattach the retaining plate.
If you have a heat gun (SMC rework station) you may be able to use it to soften the plastic retainers during removal and smash them back down later with a soldering iron but that basically never works.
Great tutorial. I got water on my laptop and had to get inside to dry it out. Worked just like you said!! Thanks!
Worst tutorial ever
Usually on a troubleshooting forum, the common sense is to EXPLAIN the situation... not just drop your frustration and leave!
Thanks! The only problem I had is with the ssd, the cover would not close with both rubber spacers installed, I took one out and used tape, then it snapped back on great!
Excelent tutorial. It is compatible with the 17-x121-dx model as well. Thanks.
Exactly what I needed to get the job done. Also, I hadn't thought of using a guitar pick before, but that was perfect for the job. Thanks!
Simply superb. Thank you.
Outstanding. Worked as written on Pavilion Notebook 17 g077cl
The only difference was the clips by the hinges - no clips fell out, none present (made no difference).
Regarding the rubber spacers on the HD - When I replaced the HD, I must have put them backwards because I had the same issue as Alex. Once I reversed them, the cover closed fine.
Again, kudos for a well written and photographed guide.
What type of memory does this model use?
The HP Pavilion - 17 g173ca uses DDR3. Mine has two 8gb modules totaling 16gb
Great job! Two differences with my HP: screws were under the two rubber feet near the hinges and two small screws were holding the CD to the top of the case. Those were a pain to access; the CD tray has small access holes. So open the tray and slide it till the holes line up for a very small diameter Philips screwdriver.
Thanks so much for providing this excellent tutorial. I successfully upgraded my hard drive to a SSD. I couldn’t have done it without you.
Really struggling to get the case off. The clips under the battery click back into place as soon as you lift the front and there seems to be resistance from the centre of the inside. Any help?
That resistance from the center usually means a screw has been missed, double check that all of the screws have been removed. If you are working on a different model than the one pictured there could be additional screws hiding somewhere.
Great work. Thx for this tutorial.
I got it open in less than an hour. Good tutorial. I was having trouble so I checked and there were those two little stickers hiding two more screws.
Great work. Thanks very much!
Great help in conquering a fear! Thank you.
simple, clair et net. Bravo! et merci beaucoup!
For the slightly color blind, they are the two circles on the left and right of the most horizontally middle screw, in the third row of screws from the bottom going up. :)
sam - crwdns2934203:0crwdne2934203:0
