HP PSC 2355 Scanner Glass Replacement
  1. HP PSC 2355 Scanner Glass Replacement, Scanner Lid: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
  2. HP PSC 2355 Scanner Glass Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With two hands, grasp the lid on both sides near the hinges and lift straight up to release the lid from each hinge.
  3. HP PSC 2355 Scanner Glass Replacement, Scanner Glass: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP PSC 2355 Scanner Glass Replacement, Scanner Glass: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the finger notch on the inside top left half of the bezel (control) panel cover.
    • Place your index finger in the notch and lift up to unsnap the panel.
    • Set the panel cover aside.
  4. HP PSC 2355 Scanner Glass Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T9 Torx screwdriver to remove the 9 mm screw.
  5. HP PSC 2355 Scanner Glass Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From the front of the printer, remove the button panel by pulling it towards you while slightly lifting it up.
  6. HP PSC 2355 Scanner Glass Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP PSC 2355 Scanner Glass Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the white ribbon cable by grasping it between your thumb and forefinger.
    • Gently pull to release the ribbon from the green circuit board.
  7. HP PSC 2355 Scanner Glass Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, use a spudger to pry the flat ribbon computer cable by the plastic connection end loose. Carefully separate it from the prongs on the button panel.
    • Now the whole button should be completely disconnected from the printer.
    • Set button panel aside.
  8. HP PSC 2355 Scanner Glass Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the T9 Torx screwdriver to remove the seven 9 mm screws on the top plastic frame around the glass.
  9. HP PSC 2355 Scanner Glass Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From the back of the printer, locate the two large plastic tabs as shown.
    • With your index fingers underneath each tab, gently and simultaneously pull the tabs towards you and upwards to release the tabs from the plastic clasps behind them.
    • Remove the whole plastic frame that holds the glass.
  10. HP PSC 2355 Scanner Glass Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP PSC 2355 Scanner Glass Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the glass/plastic bed from the edge on the side opposite of the button/control panel section.
    • As shown in the second image, gently lift the glass pane up so that it is above the plastic tab that holds it into place.
  11. HP PSC 2355 Scanner Glass Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Proceed to slide the glass pane out and over the plastic tab to remove it completely from the plastic bed.
    • Replace the glass with your new glass pane. To fully reassemble the printer, follow these instructions in reverse order.
Amber Gabaldon
crwdns2935283:001/28/14crwdne2935283:0
343 crwdns2915208:0crwdne2915208:0
New Mexico State, Team 1-4, Sheppard Spring 2014 crwdns2935289:0New Mexico State, Team 1-4, Sheppard Spring 2014crwdne2935289:0
NMSU-SHEPPARD-S14S1G4
crwdns2942667:0crwdne2942667:0 1,040
