The speakers on your HP Omni 10 tablet can be replaced with the help of this instruction. If the sound on your tablet is distorted, muted, or not working at all, changing the speakers can help. First, gently remove the battery and rear cover. Next, remove the little components covering the speaker region. Easy-to-follow instructions are included in every stage to assist you prevent breaking your gadget. Use the appropriate screwdriver, take your time, and pay close attention to the instructions to ensure a safe repair.
Remove the back cover from the tablet.
Push the black plastic security flaps into an upward position.
Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
Lift the tab on the strip up and pull it across the battery.
Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
Unhook the cord from the edge of the battery.
Pull the wire circuit out and down.
Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
Unscrew the two 3.3 mm screws using a 00 Phillip's head screwdriver.
Lift and remove micro card reader board.
Unscrew the four 3.3 mm screws using a 00 Phillip's head screwdriver.
Pull the black and white wire connector up to disconnect it.
Pull the red and black wire connector up to disconnect it.
Lift the speaker set out of their sockets.
Unhook the left speaker's connector wire to fully remove it from the device.
its order when i will get it please candly I request
