Does your HP Omen 15-ce198wm run out of battery quickly even if you're not running anything? Is it old? Perhaps it's time to replace your battery. If so, this guide will lead you every step of the way!
Note: For safety reasons, unplug everything and shut down your laptop before starting. If your battery looks swollen, stop immediately and consult this guide.
Place the laptop with the bottom facing upwards.
Remove eight black 4.7 mm screws using a Phillips #1 screwdriver.
Loosen the two captive screws on the bottom of the laptop using a Phillips #1 screwdriver.
Insert an opening tool or a pick between the bottom panel and your computer, and then push down to pull it up.
Repeat the step above across every edge, so the panel lifts up completely.
Remove the four 5.7 mm screws from the battery using a Phillips #1 screwdriver.
Use your hands to lift the battery out of the laptop.
To reassemble your device, follow these instructions in reverse order. Overall, it's an easy process. Most of the estimated time is just trying to remove the bottom panel from the laptop.
this is misleading and lying. You made me buy a $50 battery I don't need because you said to buy the ifixit battery. The 15-ce198wm uses a different battery. Unacceptable.
Hi, Christian, I'm really sorry for my mistake. When I wrote it, I was just trying to get the assignment done for my class. I never thought that people would actually follow my guide. Seeing the image of my battery and the battery linked, I can clearly see the mistake I made, as the models don't match. I'm not sure what iFixit's policies are, but I hope you can get a refund. Again, I'm really sorry for my oversight, and I will be fixing this guide so it doesn't happen again.
Fantastic instructions with pictures. I’ve never seen the inside of my laptop before. After viewing your instructions, it gave me the confidence to complete the install. Thank you!!!
