HP Omen 15-ax200ne Hard Drive Replacement
  1. HP Omen 15-ax200ne Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fully power off the laptop.
    • If you are unsure that your laptop is in hibernation mode, turn the computer off from the start menu.
    • Unplug charging cable and any external devices.
  2. HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Anti-Static Wrist Strap
    $7.95
    • Position the laptop upside down on a flat and clean surface.
    • Make sure to stay away from static discharge or wear an anti-static wrist strap.
    • Remove the two Phillips M2x5.0 screws located at the top left and top right of the laptop (circled in red).
    • Remove the eight M2.5x6.0 (circled in orange).
  3. HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Keep in mind, there are three internal clips by the battery area.
    • Slide the nylon opening tool around the edge of the base enclosure, releasing the three clips by the battery area.
    • Continue to slide the nylon opening tool around the edges of the base enclosure, doing so while loosen the cover.
  4. HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After successfully loosening the base enclosure, and removing it. You will be left with an exposed motherboard.
  5. HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the battery from the motherboard.
    • Release the battery cable from the routing channel to reveal the screws beneath.
  6. HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 2x5 screws using the Phillips screwdriver.
    • Slide the battery out of its space to remove it from the computer.
  7. HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the clip attaching the hard drive cable to the motherboard.
    • Be careful when disconnecting this clip, as it is very delicate.
    • Use your fingers or a spudger to disconnect the cable. Do not use a screwdriver for the job. It could cause damage.
    • Slide the hard drive out horizontally.
  8. HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disassemble the hard drive by removing the connector and the side brackets.
  9. HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reattach the side brackets and the hard drive connector.
  10. HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Omen 15-ax200ne Hard Drive Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the hard drive back to the original spot.
    • Reclip the hard drive to the motherboard.
Khaled Hamdan
crwdns2935283:001/14/21crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
York University, Team S2-G8, O'Regan Winter 2021 crwdns2935289:0York University, Team S2-G8, O'Regan Winter 2021crwdne2935289:0
YORK-O'REGAN-W21S2G8
crwdns2936753:030crwdne2936753:0 122
crwdns2942667:0crwdne2942667:0 3,914
