HP Officejet Pro 8620 Power Adapter Replacement
  1. HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the printer and remove the power cable.
    • Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
  2. HP Officejet Pro 8620 Power Adapter Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Officejet Pro 8620 Power Adapter Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the front door by placing your finger on the indented groove on the left side of the printer and pulling down
    • This will give you access to the two T9-TORX 13mm screws that need to be removed to release the panel.
  3. HP Officejet Pro 8620 Power Adapter Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Officejet Pro 8620 Power Adapter Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 13mm screws with a T9-TORX screwdriver by turning counter-clockwise (left).
  4. HP Officejet Pro 8620 Power Adapter Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 8620 Power Adapter Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 8620 Power Adapter Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the left side panel by placing your palm flat against the surface and pulling down.
  5. HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two screws 13mm screws with a T9-Torx screwdriver by rotating them counterclockwise.
  6. HP Officejet Pro 8620 Power Adapter Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 8620 Power Adapter Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 8620 Power Adapter Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the black cable .
    • Move all the cables and wires to the top of the motherboard to allow the power adapter underneath to be removed freely.
  7. HP Officejet Pro 8620 Power Adapter Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently bend the black ribbon cable.
    • Remove one 8mm T8 screw underneath the ribbon cable by rotating it counterclockwise with a T8 -Torx screwdriver.
    • Take out the black plastic cover and the colored wires connected to it.
    • Now you have cleared a passage for the power adapter to be taken out.
  8. HP Officejet Pro 8620 Power Adapter Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pulling out the power adapter.
    • Be careful with all the wires when pulling out the adapter.
Scott
crwdns2935283:001/24/18crwdne2935283:0
635 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G2, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S19-G2, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S19G2
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 2,666
