HP Officejet Pro 8620 CMOS Battery Replacement
  1. HP Officejet Pro 8620 CMOS Battery Replacement, Left Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 8620 CMOS Battery Replacement, Left Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 8620 CMOS Battery Replacement, Left Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the printer and remove the power cable.
    • Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
    Apparently screws are T10 not T9. T9 driver/bit works, but you'll slightly damage the screw. I use a T10 now.
    dbovey - crwdns2934203:0crwdne2934203:0
  2. HP Officejet Pro 8620 CMOS Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Officejet Pro 8620 CMOS Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the front door by placing your finger on the indented groove on the left side of the printer and pulling down
    • This will give you access to the two T9-TORX 13mm screws that need to be removed to release the panel.
  3. HP Officejet Pro 8620 CMOS Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Officejet Pro 8620 CMOS Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 13mm screws with a T9-TORX screwdriver by turning counter-clockwise (left).
  4. HP Officejet Pro 8620 CMOS Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 8620 CMOS Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 8620 CMOS Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the left side panel by placing your palm flat against the surface and pulling down.
    good day in picture no. 4 shows a small flat joint, this part is broken, I can't find its part number or its name. could you help me with this part?
    Dzamko Daniel - crwdns2934203:0crwdne2934203:0
  5. HP Officejet Pro 8620 CMOS Battery Replacement, CMOS Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently bend the black ribbon cable by using your left hand.
    • Remove the 8mm T9-Torx screw under the black plastic cover by turning counter clockwise.
  6. HP Officejet Pro 8620 CMOS Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Officejet Pro 8620 CMOS Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently move the black plastic cover to the side by using your right hand.
    • Place one finger behind the top of the motherboard where you removed the previous screw.
    • Gently pull the motherboard towards you by about an inch by using your right hand's finger.
  7. HP Officejet Pro 8620 CMOS Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the CMOS battery by using a finger from your left hand, while holding the motherboard with your right hand.
    Good instructions, but the battery dropped into the printer. Anyone know what number the battery is.
    Curt Barnes - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Michael
crwdns2935283:001/24/18crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G2, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S19-G2, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S19G2
I removed the lithium CMOS 3 volt battery, connected 2 wires at +(red) and - (black). Open a hole at plastic cover, and now I’m using 2 AA in serial, in a holder externally. To refill the cartridges , first open the cover till carriage stops in the middle. Second disconnect the 120 V power cable. Third remove the external CMOS 2 AA batteries, from the holder . Forth remove ink cartridges, refill and install them in the carriage. Insert exterior CMOS 2 AA batteries in the holder, Connect the power cable and you are good to go.
Arbaches Glaukus - crwdns2934203:0crwdne2934203:0
I removed all the board fasteners to be sure. That small metal hook down below your right thumb. Be careful there no to damage the board. 10 minutes and done!
servehimdaily - crwdns2934203:0crwdne2934203:0
Apparently the screws are T10 not T9. T9 works but you'll slightly damage the screw.
Any chance this battery might be responsible for Missing or Failed Printhead error message. I have tried a new printhead, and it didn't fix the problem. I am getting this error message on a lightly used printer. The printer is about 6 years old and just all of a sudden started failing on startup.
Howard L Ring - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 12,501
