HP Officejet Pro 6835 Sensor Chip Replacement
  1. HP Officejet Pro 6835 Sensor Chip Replacement, HP Officejet Pro 6835 Cover Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Sensor Chip Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 6835 Sensor Chip Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet Pro 6835 Sensor Chip Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Sensor Chip Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Sensor Chip Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Officejet Pro 6835 Sensor Chip Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Sensor Chip Replacement, Sensor Chip: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist the screwdriver counter-clockwise to remove the T9 screw on the sensor chip.
  6. HP Officejet Pro 6835 Sensor Chip Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pick up the sensor chip by the edges.
    • Pull the white cable to disconnect it from the sensor chip.
    • Repeat the process with the cable on the bottom.
Dimitri Charitou
crwdns2935283:001/24/18crwdne2935283:0
519 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G4, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S2-G4, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S2G4
crwdns2942667:0crwdne2942667:0 1,194
