HP Officejet 4630 Scanner Head Replacement
  1. HP Officejet 4630 Scanner Head Replacement, LCD Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement, LCD Display: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement, LCD Display: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There is a hidden screw underneath the model sticker on the front panel.
    • Peel the model sticker off the cover.
    • This will expose the T10 screw securing the panel.
  2. HP Officejet 4630 Scanner Head Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Loosen the panel cover from the printer body.
    • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
  3. HP Officejet 4630 Scanner Head Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the No-Fuss ribbon cable from the front panel.
  4. HP Officejet 4630 Scanner Head Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the seven 8mm screws using the Torx T6 screwdriver.
    • Remove the motherboard from the front-panel housing.
    • The LCD display is on the opposite side.
  5. HP Officejet 4630 Scanner Head Replacement, Power Supply: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement, Power Supply: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement, Power Supply: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the hood of the printer.
  6. HP Officejet 4630 Scanner Head Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two T10 11mm screws.
  7. HP Officejet 4630 Scanner Head Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the panels covering the power brick and cord.
  8. HP Officejet 4630 Scanner Head Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cord from the power supply.
  9. HP Officejet 4630 Scanner Head Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the power supply out from the chassis.
    • The power supply is still attached; don't pull too quickly.
  10. HP Officejet 4630 Scanner Head Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove final cable from power supply.
  11. HP Officejet 4630 Scanner Head Replacement, Scanner Head: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove eight T10 1mm screws from the top hood of the printer.
  12. HP Officejet 4630 Scanner Head Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the nylon spudger to pry the tab.
    • Lift up the entire panel.
  13. HP Officejet 4630 Scanner Head Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and flip the entire panel.
    • Be aware of the scanner head attached to the panel.
  14. HP Officejet 4630 Scanner Head Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Officejet 4630 Scanner Head Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start with the scanner head in place.
    • Unwind the ribbon from the track.
    • Detach ribbon completely.
Maya Willis
crwdns2935283:001/24/18crwdne2935283:0
418 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G3, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S18-G3, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S18G3
crwdns2935297:018crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,701
