The paper tray is what feeds paper to the printer. If the paper tray is malfunctioning, the HP OfficeJet 4650's printing function will not work. This guide will show you how to replace the paper tray.
Use two hands to carefully flip the printer upside down.
Remove the ten 14mm screws by using a 2.0 mm hex screwdriver and turning the screws counterclockwise.
Lift the left and right side flaps away from the paper tray to remove them.
Remove the left spring by grabbing the rubber tips connected to the spring and lifting up.
I WOULD LIKE TO PURCHASE A NEW PAPER TRAY FOR MY 4650 OFFICE JET PRINTER. IS THAT POSSIBLE? How much is it?
How long will it take to arrive?
I would like to purchase a paper output tray for my HP Office Jet printer 4650. How much is it? When can I expect delivery?
Remove the right spring by grabbing the rubber tips connected to the spring and lifting up.
Remove the paper tray by pulling the tray away from the printer.
Thank you Stephanie from a clumsy nearly 80yr old who had pulled the tray right out! A very clear guide to a simple job I had not got a clue how to do. Stay virus free and prosper. JG (UK)
Any ideas where a aperson could order a replacement paper tray like this one? (For an HP OfficeJet 4650 model?
I broke the back of the paper tray so my printer continually says to add paper. Where can I buy another paper tray without having to buy a brand new printer?
accidentally pulled the tray out completely. guide was excellent showing me how to get it back in.
