HP OMEN 16 Series Hard Drive Replacement
  1. HP OMEN 16 Series Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP OMEN 16 Series Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP OMEN 16 Series Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Plastic Cards
    $2.99
    • Remove the four 8 mm screws from the back panel of the laptop using a Phillips #1 screwdriver.
    • Remove the four 5 mm screws from the back panel of the laptop using a Phillips #1 screwdriver.
    • Slide a small plastic card between the crevice of the back panel of the laptop and the laptop itself.
    • Turn the card clockwise until you have a wide gap between the back panel and the laptop. Repeat this step all around the laptop to remove the back panel.
    • DO NOT insert the card too deep into the laptop, or you may damage or break the components inside the computer. Like the picture, you only need to insert a small corner of the card into the laptop.
  2. HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the hard drive on the right.
    • Remove the screw fastening the hard drive in place with a Phillips #1 screwdriver.
  3. HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The SSD will pop up at a 25 or 35-degree angle.
    • Take the SSD out slowly at an angle. You may need to slightly wiggle the SSD out.
  4. HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the new SSD into the slot at an angle without applying much pressure.
    • Re-screw the new SSD in with the Phillips #1 screwdriver.
  5. HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the spare hard drive slot on the left side of the laptop.
    • Remove the screw from the spare hard drive slot, and set it carefully aside for later.
    • Obtain your new hard drive and insert the hard drive at around a 25 to 35-degree angle, as shown in the image.
    • Again, insert the hard drive carefully, and do not apply much pressure.
    There's a spare hard drive slot?! So I can just add a second drive with a different OS?
    Is there a maximum supported amount of SSD storage, (in the same way as you can add RAM sticks but only up to total ram of 32GB max)?
    Temp Account - crwdns2934203:0crwdne2934203:0
    Yes. There is a spare hard drive slot on this model. I have added a second drive with a different OS before, so you should have no problem doing so.
    To answer your second question, I am not sure if there is a maximum supported amount of SSD storage; however, on the manufacturer's website, they have provided SSD storage up to 2 TB(something to keep in mind).
    James Heo -
    Thank you so much, both for your super quick reply and for writing this guide!
    Temp Account -
  6. HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Screw the hard drive securely to the hard drive slot using the screw that was set aside in step 5.
  7. HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP OMEN 16 Series Hard Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Obtain the back panel and push the panel back onto the laptop.
    • Make sure that the panel is on the laptop completely; this means that you should push down firmly on multiple places so that the cover is securely on the laptop.
    • Re-screw in the four 8 mm screws with the Phillips #1 screwdriver.
    • Re-screw in the four 5 mm screws with the Phillips #1 screwdriver.
James Heo
crwdns2935283:010/25/23crwdne2935283:0
226 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 4-11, Kershman Fall 2023 crwdns2935289:0CSU Los Angeles, Team 4-11, Kershman Fall 2023crwdne2935289:0
CSULA-KERSHMAN-F23S4G11
Take note that different modelnumbers in the 16 series might not have a secondary M.2 slot.
The pictures in the guide seem to be from the 16-k series (2022) while the 16-wd (2023) only has 1 slot according to other sources.
M-Hobbyist - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 91
crwdns2936753:030crwdne2936753:0 308
crwdns2942667:0crwdne2942667:0 4,444
