HP OMEN 15-ce198wm CPU Cooling Fan Replacement
  1. HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Remove back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power the laptop down fully. Remove the 10 screws on the black panel with a #2 Philips screwdriver. The two center screws (pictured in orange) at the rear are captive and do not need to be removed entirely, only loosened.
  2. HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Remove battery pack: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery for safety. Remove the four screws holding down the battery pack. Lift straight up and slide slightly forward to fully unseat the battery pack from the hold-down tabs at the bottom of the pack.
  3. HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Remove hold-down bracket and trim: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Remove hold-down bracket and trim: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Remove hold-down bracket and trim: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 10 screws pictured. The two orange-marked screws must be removed to pull the vent-style piece off the back of the laptop to access a hidden screw labeled with the green arrow. The vent will pop off with light force pulling away from the computer. Once all screws are removed the hold-down bracket over the fan will come right off
  4. HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Remove NVME SSD: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Remove NVME SSD: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hold-down screw for the SSD. Gently lift the SSD away from the thermal pad and pull it out of the connection slot.
  5. HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Disconnect fan cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Disconnect fan cable: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull directly up on the connector body, and be careful not to pull the wires off the fan. Since there is no locking mechanism holding the connector in place, mild force should be sufficient to disconnect the fan from the motherboard.
  6. HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Transfer thermal pad to new fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Transfer thermal pad to new fan: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This fan will include a place for the SSD's thermal pad. If your pad is in good shape, carefully transfer it to a new fan. If the pad is damaged, it must be replaced. The OEM pad should be sticky on the back to hold it on the new fan.
  7. HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Remove fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Remove fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At this point, the old fan can be removed. Note the cable running over one of the fan mounting locations. Take care not to catch this cable during the removal of the fan. Slide the bracket arm under the cable and remove the fan.
  8. HP OMEN 15-ce198wm CPU Cooling Fan Replacement, Reassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reassembly is the reverse of teardown. To assemble the laptop, follow the steps in the opposite order. When reconnecting the fan, ensure the connector is appropriately lined up with the port on the motherboard to prevent damage to the pins.
Blake Taylor
crwdns2935283:001/01/18crwdne2935283:0
182 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 396
