Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
Unscrew the 8 screws on the back cover.
There are also two screws in the battery area that need to be removed.
Use an opening tool to help remove the back cover.
Use a Phillips screwdriver to remove the screw holding down the wifi chip.
Remove the two wires connected to the wifi chip.
Gently pull the wifi chip out and replace with a new wifi chip.
