HP Notebook 15-ay011nr Solid-state drive board Replacement
    • Before disassembling the computer, follow these steps:
    • Shut down the computer
    • If you are unsure whether the computer is in hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect all external devices connected to the computer
    • Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer
  1. HP Notebook 15-ay011nr Solid-state drive board Replacement, Removing the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the battery:
    • Position the computer upside down on a flat surface
    • Slide the battery lock latch (1)
    • Slide the battery release latch (2)
    • Remove the battery (3) from the computer
  2. HP Notebook 15-ay011nr Solid-state drive board Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the optical drive:
    • Remove the Philips PM2.5x6.0 screw (1)
    • Remove the optical drive (2) by sliding it out of the optical drive bay
  3. HP Notebook 15-ay011nr Solid-state drive board Replacement, Bottom Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the bottom cover:
    • Position the computer upside down the the front toward you
    • Remove the two rubber feet from the rear of the bottom of the computer (1)
    • Remove the 11 Philips PM2.5x6 screws (2) from the bottom of the computer
    • Remove the 2 Philips PM2x2 screws (3) from the optical drive bay
  4. HP Notebook 15-ay011nr Solid-state drive board Replacement, Solid-state drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the solid-state drive
    • Remove the Philips PM2x2 screw (1) that secures the drive to the system board
    • Remove the drive (2) by pulling it away from the connector
    • To remove the solid-state drive board:
    • Disconnect the cable from the system board (1)
    • Remove the two Philips PM2.0x3.0 screws (2) that secures the solid state drive board to the computer
    • Lift the board out of the computer (3)
Alec Ringberg
crwdns2935283:008/05/18crwdne2935283:0
625 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 56
