HP Mini 311 RAM Replacement
    1. HP Mini 311 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Mini 311 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Mini 311 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
    2. HP Mini 311 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Mini 311 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the battery away from the device to remove.
    1. HP Mini 311 RAM Replacement, Memory Shield: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
      • The screws will remain in the shied.
    2. HP Mini 311 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Mini 311 RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the memory shield up and remove from the laptop.
    1. HP Mini 311 RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Mini 311 RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Mini 311 RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Firmly press on the metal pins located on both sides of the RAM.
      • One side of the RAM will pop up to form a 40 degree angle with the body of the laptop.
      • Simply grab and remove the RAM from the device.
Christian Santoyo
crwdns2935283:001/31/13crwdne2935283:0
495 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-4, Maness Winter 2013 crwdns2935289:0Cal Poly, Team 20-4, Maness Winter 2013crwdne2935289:0
CPSU-MANESS-W13S20G4
crwdns2935297:067crwdne2935297:0
4 GB modules are not supported it seems.
You may see posts in the HP Support Forum saying that the Mini 311 will accept a 4 GB module. Possibly this is true for the Pavilion DM, but not the Mini 311.
The service manual says only 2GB or 1 GB are supported.
Other people posted that they tried a 4GB module and it did not work.
rafss - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
FYI, The link to buy the suggested part is wrong and not compatible.
Christine Fowler - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 4,209
