HP Mini 210-2070NR Keyboard Replacement
  1. HP Mini 210-2070NR Keyboard Replacement, Battery and Service Access Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Mini 210-2070NR Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Mini 210-2070NR Keyboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Mini 210-2070NR Keyboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Mini 210-2070NR Keyboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR Keyboard Replacement, Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Mini 210-2070NR Keyboard Replacement, Keyboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a 00 Phillips screwdriver, unscrew and remove the three 2.0 X 5.0 screws that connect the keyboard to the computer.
    • Each of the screws are labeled with small keyboards next to them.
    • Flip the computer over so that the front is facing you.
  6. HP Mini 210-2070NR Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Mini 210-2070NR Keyboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Mini 210-2070NR Keyboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the computer screen as far as possible. It should be able to lay flat on whatever surface you are working on.
    • Pry along the rear edge of the keyboard away from the PC with the plastic opening tool.
    • Once enough of an opening has been established, gently grasp the edge and pull the keyboard towards you.
    • There is a cable connecting the keyboard to the laptop, so do not attempt to fully remove the keyboard yet or you will damage your device.
  7. HP Mini 210-2070NR Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Mini 210-2070NR Keyboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernail to flip up the black retaining flap attached to the keyboard ZIF connector.
    • Pull the keyboard cable out of its socket to disconnect it.
  8. HP Mini 210-2070NR Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the keyboard by lifting it away from the computer.
Sean Kuster
crwdns2935283:010/05/12crwdne2935283:0
91 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-23, Amido Fall 2012 crwdns2935289:0Cal Poly, Team 3-23, Amido Fall 2012crwdne2935289:0
CPSU-AMIDO-F12S3G23
crwdns2942667:0crwdne2942667:0 1,711
