crwdns2959928:0crwdne2959928:0 ↓By using this guide a user will be able to effectively remove the RAM portion of the HP Mini 210-199DX for either replacement or installation of a new RAM card.
Spudger4.9
Unplug the netbook.
Secure the netbook in a upright position.
Slide the plastic battery latch that secures it into the netbook.
Keep thumb secure on the right tab as you begin to remove the battery.
Press down on the two orange buttons to release.
If the case does not pop off, begin to use Spudger to pry the case off the back.
Place the spudger on corners and openings in order to begin removal of the back.
Continue this on all corner until the case comes fully off of the back.
Use spudger to carefully pull the holding devices back.
