Installing a new WiFi card is quick and simple.
The WiFi card in the HP Mini 210 uses a Mini PCIe interface, which is the de-facto standard on recent laptops. Please ensure you install an official HP verified wireless card to prevent running into errors.
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Slide the battery out from the netbook.
Turn the netbook to view its edge.
Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Pull the back case off from the front edge.
Pop out the two gold connectors from the antenna wires on top of the WiFi card using a plastic opening tool. This will allow you to dislodge the WiFi card from the rest of the netbook.
Remove the two 3.9 mm screws on top of the WiFi card using the Phillips #00 screwdriver.
Gently pull the WiFi card out of its slot. Be sure to pull the card up and out of the slot towards you.
