HP Mini 210 Netbook WWAN Card Replacement
  1. HP Mini 210 Netbook WWAN Card Replacement, WWAN Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 Netbook WWAN Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery out from the netbook.
  3. HP Mini 210 Netbook WWAN Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 Netbook WWAN Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 Netbook WWAN Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the back case off from the front edge.
  6. HP Mini 210 Netbook WWAN Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Mini 210 Netbook WWAN Card Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two gold antenna cables from the WWAN card using a plastic opening tool.
  7. HP Mini 210 Netbook WWAN Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Mini 210 Netbook WWAN Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two Phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board.
  8. HP Mini 210 Netbook WWAN Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the WWAN card by pulling the WWAN card out at an angle.
Install the new WWAN card and then to reassemble your device, follow these instructions in reverse order.
Heather Freed
crwdns2935283:010/06/12crwdne2935283:0
723 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-17, Amido Fall 2012 crwdns2935289:0Cal Poly, Team 9-17, Amido Fall 2012crwdne2935289:0
CPSU-AMIDO-F12S9G17
apakah benda tersebut ada dalam paket penjualan, atau dijual terpisah?
rioarayana - crwdns2934203:0crwdne2934203:0
I wonder sims slot on hp mini and other major brands also. Toshiba ,Acer
Deborah Kisilywicz - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,942
