These steps will show how to replace the left side panel from the printer. This prerequisite guide will be used for the power plug removal, motherboard removal, and half of the drive belt removal guides.
Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
Now that the pry points are free lift up the front panel.
Unscrew the #1 Phillips screw 6mm on the back of the printer.
Using the plastic spudger, remove the button housing from the top left of printer.
Once the housing is removed, remove the three buttons.
Use the plastic spudger to remove the side panel. There are three main prying points as shown.
mine had a PH2 screw on the printer back thru the side panel into the aluminum serial plate/back, placed in the 2nd and third picture in the tab with a round screw hole and square locator hole. Critical clips were center back, center top and center bottom, and two points on the front.
edit, i see the screws talked about in step 3. sorry.
With all pry points free, remove the side panel.
How to replace the HP 2055 motherboard
my two main points were precisely under the rubber feet, they were surprisingly difficulty to dislodge.
Peter Taffs - crwdns2934203:0crwdne2934203:0
