HP LaserJet P1102w Drive Belt Replacement
  1. HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
  2. HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that the pry points are free lift up the front panel.
  3. HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
  4. HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic spudger, remove the button housing from the top left of printer.
  5. HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the housing is removed, remove the three buttons.
  6. HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
  7. HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With all pry points free, remove the side panel.
  8. HP LaserJet P1102w Drive Belt Replacement, Drive Belt: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement, Drive Belt: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement, Drive Belt: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Refer to the prerequisite guide to take off the front panel off.
    • With a #1 Phillips screwdriver remove only the top Phillips 60mm screw.
    • With the spudger pry the side panel off. There will be four flanges to unhitch.
  9. HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With side panel removed, there will be four Phillips 60mm screws to unscrew using a #1 Phillips screwdriver.
  10. HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove top two big gears using tweezers.
    • Take note of gear placement.
  11. HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP LaserJet P1102w Drive Belt Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the #1 Phillips screwdriver remove the 60mm Phillips screw holding the belt tension-er.
    • With the screw removed, pull tension-er out.
    • Use tweezers to remove the loose drive belt.
Jerome Etten
crwdns2935283:010/04/18crwdne2935283:0
763 crwdns2915208:0crwdne2915208:0
UW Stout, Team S6-G4, Ogden Fall 2018 crwdns2935289:0UW Stout, Team S6-G4, Ogden Fall 2018crwdne2935289:0
UWSTOUT-OGDEN-F18S6G4
the tight side panel clips make this a difficult procedure, so take care both disassembling and assembling, for example make sure the power button is aligned with the level components behind before you push to clip the front home, as misalignment can break or dislocate internal parts.
Peter Taffs - crwdns2934203:0crwdne2934203:0
Que dois je faire si mon imprimante fait beaucoup de bruit en imprimant et que la totalité de feuille imprimée ne sort pas?
anelka VILPIGUE - crwdns2934203:0crwdne2934203:0
In my case, the roller is worn out. I haven't been able to find a replacement. Can you give me the part code so I can buy it?
EleCom - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 3,608
