Pull on the two tabs on the back of the printer to release the left side cover.
Remove the cover by rotating it towards the front of the printer.
With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
Lift the cover off of the printer.
Remove 4 screws on the back of the printer.
Remove the back cover.
Remove 2 screws on the back of the printer, one on the left, and one on the front.
Disconnect the control panel cable and remove the top cover.
Disconnect the fan cable from the main board of the printer.
Remove the retaining clip holding the fan in.
Remove the 2 screws holding the fan in.
Remove the fan cable from the cable guide.
Disconnect one cable from the main board of the printer.
Disconnect the duplexer solenoid cable from the duplexer PCB.
Remove one screw on the duplexer PCB and remove the PCB from the printer.
Remove 3 screws holding the duplexer gears to the printer and remove the gears.
Remove one screw to remove the solenoid from the printer.
