HP G62-223CL Optical Drive Replacement
  1. HP G62-223CL Optical Drive Replacement, Battery Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP G62-223CL Optical Drive Replacement, Battery Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Optical Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Optical Drive Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate two Phillips head retaining screws which secure the hard drive compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Optical Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the 6 mm Phillips head screw to the left of the hard drive.
    • Use a Phillips #0 screwdriver to remove the screw.
  5. HP G62-223CL Optical Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP G62-223CL Optical Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screw is removed, use a plastic opening tool and place it between the body of the computer and the optical drive.
    • Apply enough pressure to loosen the optical drive.
    • The optical drive can then be removed by hand.
Garret Layton
crwdns2935283:001/13/15crwdne2935283:0
669 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Sullivan Winter 2015 crwdns2935289:0USF Tampa, Team 1-4, Sullivan Winter 2015crwdne2935289:0
USFT-SULLIVAN-W15S1G4
crwdns2942667:0crwdne2942667:0 1,273
