HP G62-223CL Hard Drive Replacement
  1. HP G62-223CL Hard Drive Replacement, Battery Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP G62-223CL Hard Drive Replacement, Battery Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP G62-223CL Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two Phillips head retaining screws which secure the hard drive compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the three 6 mm Phillips head screws for the hard drive.
    • Use a Phillips #0 screwdriver to remove the screws.
  5. HP G62-223CL Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive from the compartment.
    • Pull the connector cable from the end of the hard drive.
  6. HP G62-223CL Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two 6 mm Phillips head screws on each side of the hard drive.
    • Remove the cover from the hard drive.
Garret Layton
crwdns2935283:001/13/15crwdne2935283:0
669 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Sullivan Winter 2015 crwdns2935289:0USF Tampa, Team 1-4, Sullivan Winter 2015crwdne2935289:0
USFT-SULLIVAN-W15S1G4
crwdns2942667:0crwdne2942667:0 2,774
