HP G60T-600 CTO RAM Replacement
  1. HP G60T-600 CTO RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP G60T-600 CTO RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn your device over and orient it so the battery is facing you.
  5. HP G60T-600 CTO RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP G60T-600 CTO RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP G60T-600 CTO RAM Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the following 5mm screws using a Phillips head #0 screwdriver.
    • Remove the cover.
  6. HP G60T-600 CTO RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP G60T-600 CTO RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP G60T-600 CTO RAM Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your fingers on little metals tabs on both sides of the RAM casing.
    • Push the tabs towards the sides. This should cause the RAM to pop up.
  7. HP G60T-600 CTO RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on it with medium force at the angle it is oriented.
Dominic DeSantis
crwdns2935283:010/19/16crwdne2935283:0
772 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-5, Catania Fall 2016 crwdns2935289:0UMass Dartmouth, Team 4-5, Catania Fall 2016crwdne2935289:0
UMASSD-CATANIA-F16S4G5
crwdns2942667:0crwdne2942667:0 242
