HP G60 RAM Replacement
  1. HP G60 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP G60 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP G60 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, you should to remove the battery to avoid electric shocks
    • Slide and unlock the battery, then, lift it
  2. HP G60 RAM Replacement, RAM cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP G60 RAM Replacement, RAM cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP G60 RAM Replacement, RAM cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two screws with a not too large screwdriver
    • Now lift the cover, the screws are part of the cover
  3. HP G60 RAM Replacement, Eject RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP G60 RAM Replacement, Eject RAM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP G60 RAM Replacement, Eject RAM: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the little aluminum locks at the top and the bottom of the ram
    • The memory will lift, then pull it
    • Make this with the another RAM slot
  4. HP G60 RAM Replacement, New RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP G60 RAM Replacement, New RAM: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP G60 RAM Replacement, New RAM: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The new RAM memory should to be insert in a 45 degrees angle
    • Then, push it and the memory will lock by itself
    • Make this with the second memory
  5. HP G60 RAM Replacement, RAM cover (Again): crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP G60 RAM Replacement, RAM cover (Again): crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP G60 RAM Replacement, RAM cover (Again): crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the cover from right to left, then, screw it
    • If cover is lifted, press it softly and secure it
crwdns2935229:05crwdne2935229:0
jimenezser
crwdns2935283:008/29/12crwdne2935283:0
3 899 crwdns2915208:0crwdne2915208:0
Thanks for verifying the RAM replacement and that it was as easy as I thought it was, but that made me a bit nervous, being much more comfortable building desktops as large as my or my customer's budget would allow!
Take 'em out, put new ones back in. As a technical writer, I also appreciate that you kept it to the point without creating further questions to complicate that which is not complicated. Thanks again. Will check out some out your other work.
J Brent Masters - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,237
