This replacement guide is for the daughterboard of the HP Envy x360 m6-w103dx. The daughterboard contains a USB port and SD card slot.
Make sure the computer is unplugged and powered off before touching any internal parts.
Removing the daughterboard is not dangerous and doesn’t require any special technical skills.
Using an opening pick, remove the 4 rubber feet and 4 screw covers.
Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
Open the laptop carefully, with the keyboard face up.
Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
Lift the keyboard until you can see the cables connected to the motherboard.
Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
Detach the keyboard.
Remove the four 6 mm Phillips #0 screws holding the battery in place.
Unplug the ribbon cable by flipping up the white tabs on the ZIF connectors and gently sliding the ribbon cables out of their sockets.
Unplug the battery connector by grasping the small white tabs on either side of the connector and pulling down towards the battery.
Unscrew the two screws from the daughterboard using a Phillips #0 screwdriver.
Use the plastic opening tool to remove the daughterboard.
