HP Envy x360 m6-w103dx Battery Replacement
  1. HP Envy x360 m6-w103dx Battery Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 m6-w103dx Battery Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy x360 m6-w103dx Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy x360 m6-w103dx Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 6 mm Phillips #0 screws holding the battery in place.
    • The white arrows on the battery point to where each screw is.
  6. HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the ribbon cable by flipping up the white tabs on the ZIF connectors and gently sliding the ribbon cables out of their sockets.
    • Unplug the battery connector by grasping the small white tabs on either side of the connector and pulling down towards the battery.
  7. HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy x360 m6-w103dx Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift out the battery.
    • You may need to peel off the ribbon cable and replace it after installing the new battery if your replacement part doesn't have one already adhered.
crwdns2935229:010crwdne2935229:0
Steven Ngo
crwdns2935283:010/10/19crwdne2935283:0
963 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G2, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S12-G2, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S12G2
crwdns2935297:023crwdne2935297:0
Thank you Steven for the provided guide, it helped a lot! There are no guides available on the internet particular for the HP Envy x360 m6-w103dx Battery Replacement. And using the IFIXIT tool kit, it was much easier to replace the battery…love these tools. Awesome job!
Charlie - crwdns2934203:0crwdne2934203:0
Thank you, I was able to change the battery successfully, not an easy task with this model of laptop. I would not have been able to do it without your instructions.
Nancy Gaj - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 82
crwdns2942667:0crwdne2942667:0 10,196
