Hard Drives are responsible for permanently storing and retrieving data on a computer. This guide will instruct how to replace a faulty Hard Drive.
Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
Remove the six 5.2 mm screws using the Torx T5 screwdriver.
Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
Remove the two 4.6mm screws securing the hard drive in place using the Phillips #0 screwdriver.
Disconnect the cable plugged into the hard drive and remove the hard drive from the device.
