This is a simple guide to replace the headphone jack if it is loose or broken. You will need an anti-static wristband, a Philips head 1 screwdriver, and a blue nylon opening tool to complete this replacement guide.
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
Lift up the port with the tool.
Lift the battery out of the laptop with your hands.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
Make sure you are wearing an anti-static wrist strap.
Remove the four screws from the blue board that contains the headphone jack using the Phillips head 1 screwdriver (one 4 mm black screw, one 3 mm black screw, and two 4.5 mm silver screws).
Insert the plastic opening tool underneath the connector on the black flexible flat cable with the blue plastic stripe.
Lift the opening tool to open the connector.
Use your fingers to slide the ribbon cable out of the connector.
Hold the left side of the board between your fingers.
Lift the edge upwards enough to clear the other components in the way.
Slide and rotate to lift the board out of the designated slot for the board.
