The cooling fan is a key component of a laptop. This component keeps the computer cool while operating. If the fan fails, the computer may overheat and damage components in the computer. This guide will show in-depth steps on how to safely remove a cooling fan from an HP Envy x360.
Remove the rubber strip along the top of the backside of the computer.
On the back panel of the device, remove the four (4) 2.5 mm screws at the top of the photo using a Phillips #0 screwdriver.
Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
To remove the back cover, use the spudger to lift up on the edges of the cover.
Use a suction cup to assist in lifting the back cover
Use the Philips #0 screwdriver to remove seven 2 mm screws from battery.
Lift and pull the front of the battery up and out away from the connector to remove.
Using a Philips #0 screwdriver, remove the three 2 mm screws located around the cooling fan as shown in this picture.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the connector clip with the tweezers.
Remove the four spring loaded screws with a Philips #1 screwdriver.
