HP Envy x360 15m-bp111dx Hard Drive Replacement
  1. HP Envy x360 15m-bp111dx Hard Drive Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15m-bp111dx Hard Drive Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy x360 15m-bp111dx Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy x360 15m-bp111dx Hard Drive Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Hard Drive Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15m-bp111dx Hard Drive Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy x360 15m-bp111dx Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy x360 15m-bp111dx Hard Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the battery, and pull it towards you to remove it.
  5. HP Envy x360 15m-bp111dx Hard Drive Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The hard drive bay is located in the lower left corner of the computer.
    • The hard drive will be covered by a black rubber sheath which can be removed by simply pulling it off of the hard drive (not pictured).
  6. HP Envy x360 15m-bp111dx Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy x360 15m-bp111dx Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy x360 15m-bp111dx Hard Drive Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the rubber casing away from the drive (not pictured here) and gently lift the hard drive out of the computer.
    • Unplug the drive from power by grabbing the SATA / power cable on the plastic edge and pulling it away from the drive.
    • Do not disconnect the ribbon cable from the motherboard.
  7. HP Envy x360 15m-bp111dx Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The hard drive is now removed and can be replaced.
Ross Snead
crwdns2935283:002/22/22crwdne2935283:0
162 crwdns2915208:0crwdne2915208:0
Clemson, Team 2-2, Hunter Spring 2022 crwdns2935289:0Clemson, Team 2-2, Hunter Spring 2022crwdne2935289:0
CLEM-HUNTER-S22S2G2
crwdns2942667:0crwdne2942667:0 591
