HP Envy x360 15-u473cl RAM Replacement
  1. HP Envy x360 15-u473cl RAM  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15-u473cl RAM  Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off your laptop before beginning disassembly.
    • Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
    • Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
  2. HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
  3. HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device right side up and open the lid.
    • Insert the plastic opening tool in between the keyboard plate and the base of laptop.
    • Run the tool along seem, prying up as you go.
    • Separate the keyboard plate from the base, lifting from the front.
  4. HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
    • Remove the keyboard plate from the device.
  5. HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
  6. HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 4mm screws using the Phillips #0 screwdriver.
  7. HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery from the motherboard.
    • There may be tamper-proof tape holding the battery in place. Remove the tape if present.
    • Remove the battery from the device.
  8. HP Envy x360 15-u473cl RAM  Replacement, Fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 4mm screws using the Phillips #0 screwdriver from the device fan.
  9. HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the fan from the motherboard using the spudger.
    • Remove the fan from the device.
  10. HP Envy x360 15-u473cl RAM  Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15-u473cl RAM  Replacement, Motherboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 4mm screws with the Phillips #0 screwdriver.
    • Remove one 3mm screw with the Phillips #00 screwdriver.
  11. HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the 2 white ribbon cables using the plastic opening tool.
    • Disconnect the two black cable bundles using the plastic opening tool.
  12. HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy x360 15-u473cl RAM  Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the charging port wire bundle from the motherboard using the plastic opening tool.
    • Disconnect the wireless card by pulling away from the black transistor using the spudger.
    • Remove the motherboard.
  13. HP Envy x360 15-u473cl RAM  Replacement, RAM: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Envy x360 15-u473cl RAM  Replacement, RAM: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Envy x360 15-u473cl RAM  Replacement, RAM: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use both fingers to push the tabs to the side and release the RAM.
    • Remove the RAM chip by pulling away from the connector.
    • Repeat the procedure for the second RAM chip.
Matthew Ortman
crwdns2935283:011/07/19crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
IUPUI, Team S3-G3, Harley Fall 2019 crwdns2935289:0IUPUI, Team S3-G3, Harley Fall 2019crwdne2935289:0
IUPUI-HARLEY-F19S3G3
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 934
