HP Envy x360 15-u473cl Hard Drive Replacement
  1. HP Envy x360 15-u473cl Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15-u473cl Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off your laptop before beginning disassembly.
    • Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
    • Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
  2. HP Envy x360 15-u473cl Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
  3. HP Envy x360 15-u473cl Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15-u473cl Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device right side up and open the lid.
    • Insert the plastic opening tool in between the keyboard plate and the base of laptop.
    • Run the tool along seem, prying up as you go.
    • Separate the keyboard plate from the base, lifting from the front.
  4. HP Envy x360 15-u473cl Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
    • Remove the keyboard plate from the device.
  5. HP Envy x360 15-u473cl Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
  6. HP Envy x360 15-u473cl Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 4mm screws using the Phillips #0 screwdriver.
  7. HP Envy x360 15-u473cl Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery from the motherboard.
    • There may be tamper-proof tape holding the battery in place. Remove the tape if present.
    • Remove the battery from the device.
  8. HP Envy x360 15-u473cl Hard Drive Replacement, Hard Drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  9. HP Envy x360 15-u473cl Hard Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Envy x360 15-u473cl Hard Drive Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover by using the black spudger to lift up on the edges of the cover.
    • Using a suction cup to assist in lifting the back cover.
    • Use the Philips #0 screwdriver to remove six M2.x3.2 screws from the battery.
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
    • Lift and pull the front of the battery up and out (away from the connector) to remover.
    • Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan.
    • Be careful as the fan might be sharp in some places when removing it.
  10. crwdns2935267:0crwdne2935267:0
    • Remove the connector clip with the tweezers.
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
    • Remove the cooling fan.
Maximillian McDonald
crwdns2935283:001/13/18crwdne2935283:0
784 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G2, Ramos Winter 2018 crwdns2935289:0Eastern Washington University, Team S1-G2, Ramos Winter 2018crwdne2935289:0
EWU-RAMOS-W18S1G2
crwdns2942667:0crwdne2942667:0 2,117
